Coilover Setups, Lets see them!
Old Jul 7, 2017 | 12:21 PM
Rlozano's Avatar
Default Coilover Setups, Lets see them!
I'm starting to dig around and plan a coilover set up for my 2000 D2. I know there is a gentleman up here in Fresno with a nice setup but wondering what others have done. Pictures and info on possible issues you came across while fabricating would be greatly appreciated. Thanks in advance.
Old Jul 7, 2017 | 02:22 PM
ZGPhoto's Avatar
A coilover setup is worth more than most D2s, there's not going to be many if at all on here.
Old Jul 7, 2017 | 02:24 PM
KingKoopa's Avatar
Yeeaah, personally I don't see the point unless you are going to switch to a long travel IFS setup and a likewise long travel three or four link rear end.
Old Jul 7, 2017 | 04:56 PM
Rlozano's Avatar
My tires and ham radio in the car are worth more than most D2's! If that theory is how I went about upgrading my car I would have been **** out of luck a long long time ago! But I get what your saying, but I don't plan on selling this car and it has a different kind of value to me. Fabricating things and troubleshooting is all part of what makes my wheeling hobby fun for me.
Old Jul 7, 2017 | 04:59 PM
Rlozano's Avatar
You are correct, I didn't plan on putting a street coiler set, but a long travel 3 or 4 point setup. When you see legit flex and stability climbing over rocks out on the trail and Im teetering over every object I get a little jealous. I was also thinking about trying to get a D1 suspension set up on my D2 but wondered if I fabricate everything myself if the coilovers would gain me function and a little something you don't see everyday.
Old Jul 7, 2017 | 05:12 PM
KingKoopa's Avatar
You won't gain any functionality over a retained coil spring and long shock unless you are talking about a dedicated rock crawler or pre-runner. In both cases you will be completely re-engineering the entire chassis and might as well have started with a from scratch buggy.
Old Jul 7, 2017 | 05:20 PM
Rlozano's Avatar
I've yet to see a D2 have solid up and down travel on a setup which required no fabrication or even extensive fabrication. As far as gain over a retained coil spring setup, I was sure you lost up travel which is why they require the large bump stops. I may be wrong here though I am new to off road suspension setups and only barely starting to read into it.
Old Jul 7, 2017 | 05:25 PM
KingKoopa's Avatar
If you haven't seen an D2 articulate well with a basic setup then you haven't looked very hard.
And I'm not sure how a retained coil would prevent up travel... it will prevent down travel if the coil is too stiff and retained on both ends but the way around that is one end retention and cone on the other, both of which are bolt on applications.
Old Jul 7, 2017 | 05:27 PM
Rlozano's Avatar
I mean with a long travel set up not a plus 2. Dislocation cones I have tried and didn't really work well, just didn't provide enough force to prevent slipping and still didn't get me any forward movement like I wanted.
TRIARII
Aug 27, 2015 04:08 PM
jwigum
Nov 14, 2014 04:54 PM
expeditionnw
Oct 18, 2013 10:54 AM
lr2001silver
Nov 2, 2012 05:16 PM
05LandRover
Off Topic
Mar 29, 2005 05:37 PM
