Cold Start Idle Too Fast
Old Apr 20, 2022 | 05:03 AM
StuffedParrot's Avatar
4th Gear
Default Cold Start Idle Too Fast
Hello,
I recently stripped down and replaced the head gaskets on my year 2000 4.6 ltr Thor engine.
Everything ran perfectly before the strip-down (apart from the blown head gasket).
I now find that when starting from cold, the revs shoot straight up to 2500-3000 rpm.
Any suggestions would be gratefully received because it never did that before strip-down.
Kind regards,
Tony
Old Apr 20, 2022 | 06:48 AM
Best4x4's Avatar
Check throttle cable adjustment and CC cable adjustment.
Old Apr 20, 2022 | 07:04 PM
JohnZo's Avatar
Sounds like what happens on D1s when the TPS gets shifted and gives a higher signal than baseline. Fixed by resetting the adaptive trims, or by rotating the TPS to read lower than baseline. Don't know if that problem propagated to D2s.
Old Apr 21, 2022 | 05:53 AM
4th Gear
Thank you. I shall have another look over the weekend.
Old Apr 21, 2022 | 09:53 AM
Frank4's Avatar
I just did head gaskets and this happens every time I’ve done it. It’s the throttle cable.
Old Apr 21, 2022 | 10:06 AM
4th Gear
Thank you.
Would you mind letting me know what you do to rectify it the times it's happened to you please as it looks fine on mine?
Tony
Old Apr 21, 2022 | 10:17 AM
whowa004's Avatar
It shouldn't be taught with the motor off, should be able to press on both throttle and CC cable and there should be some play before you actually cause the throttle open.
j.riehl18
Jan 22, 2022 06:20 PM
Ian Mitchell
Dec 16, 2019 05:33 PM
Friday Night Disco
May 26, 2019 08:54 PM
y2motoskier
Apr 28, 2012 02:45 PM
y2motoskier
Apr 28, 2012 02:31 PM
