complete coil conversion kit or coils only?
Appears I will need complete replacement of air suspension system. I have decided to convert to coil springs. Do I need to purchase the complete conversion kit as package? I have seen some sites(4x4 sites) recommending simply medium coils and coils only. What other parts needed to do this switch?
RE: complete coil conversion kit or coils only?
Rear end of car has hit bump limit. I believe the bellows have leaked, it happened overnight when our temperatures hit single digits on Saturday and have stayed in teens and low 20's during the day. Could system be frozen? I took the car to a European import service and they gave diagnosis, but they do not specialize in Rovers.
on
The bags just don't start leaking and both drop as you described.
Your ECU is not allowing the bags to refill. I don't usually recommend this, but it worked on mine recently, assuming you have your radio code, unhook your battery for the day, then connect it, start the engine, close the door and see if it will reset.
If it doesn't, you will need to get it in and have a mechanic with either a test book or an Auto Logic scanner, test and rest the computer.
Mike
Mike
Bostonc16
03-07-2015 10:32 AM
Paul Grant
11-30-2012 12:48 PM
Lincoln Tarantino
04-04-2012 01:20 PM
Paul Grant
12-11-2011 05:50 PM
b_woodroaster
11-05-2010 08:54 AM
