complete coil conversion kit or coils only?
Old Jan 15, 2007 | 07:11 PM
bennycisco's Avatar
Default complete coil conversion kit or coils only?
Appears I will need complete replacement of air suspension system. I have decided to convert to coil springs. Do I need to purchase the complete conversion kit as package? I have seen some sites(4x4 sites) recommending simply medium coils and coils only. What other parts needed to do this switch?
Old Jan 15, 2007 | 07:47 PM
Default RE: complete coil conversion kit or coils only?
What is wrong with your SLS? Would you rather keep it if you could get the parts alot cheaper?
If you do go for the conversion, a kit can be the easier way to go.
What is wrong with your truck/
Mike
Old Jan 15, 2007 | 11:54 PM
rinmud's Avatar
take it to a shop with t-4 then we can talk try not to f--k yourself
Old Jan 16, 2007 | 10:47 AM
So what is wong with your truck, they never need a complete replacement unless diagnoised by someone who didn't know what he was talking about?
Mike
Old Jan 16, 2007 | 12:34 PM
bennycisco's Avatar
Rear end of car has hit bump limit. I believe the bellows have leaked, it happened overnight when our temperatures hit single digits on Saturday and have stayed in teens and low 20's during the day. Could system be frozen? I took the car to a European import service and they gave diagnosis, but they do not specialize in Rovers.
Old Jan 16, 2007 | 09:18 PM
The bags just don't start leaking and both drop as you described.
Your ECU is not allowing the bags to refill. I don't usually recommend this, but it worked on mine recently, assuming you have your radio code, unhook your battery for the day, then connect it, start the engine, close the door and see if it will reset.
If it doesn't, you will need to get it in and have a mechanic with either a test book or an Auto Logic scanner, test and rest the computer.
Mike
Old Jan 17, 2007 | 12:27 PM
bennycisco's Avatar
Hopefully that will work, because I just recently replaced the battery (two days before incident) after the car sat for nearly 5 months with a dead battery. Would changing to a new battery caused the reset not to take place?
Old Jan 17, 2007 | 01:32 PM
Possibly.
It can't hurt to try .
Mike
Old Jan 18, 2007 | 03:12 PM
bennycisco's Avatar
FIXED!!! The fuse was blown for the SLS in fuse compartment under hood; replaced it myself.
Old Jan 20, 2007 | 11:52 PM
disco03hse's Avatar
[align=left]Holy ****!!! you just saved a butt load of money...
[/align]
Bostonc16
Mar 7, 2015 10:32 AM
Paul Grant
Nov 30, 2012 12:48 PM
Lincoln Tarantino
Apr 4, 2012 01:20 PM
Paul Grant
Dec 11, 2011 05:50 PM
b_woodroaster
Nov 5, 2010 08:54 AM
