Compomotive Wheels
Yes you are supposed to use Hub Centric rings when using LR3/LR4 wheels on a D2/P38, but all the sets I've tried = just rattle around and never even make contact with the rim to do any good other than rattle around..... I've tried several sets with the same results with OEM LR LR3/LR4 wheels and the Black Rhino wheels. In the end I just install one lug nut until the wheel centers itself on the lug centric lug nut, and then I add the others. I have a set of Black Rhino wheels on my 99 D2 off of an LR3 without any Hub Centric rings at all and zero issues. You just have to make sure the wheel centers itself and you should be fine.
