Concerns with not driving D2 often
on
I often don't drive mine for a couple of weeks at a time. When I had a weak battery it would go flat and I would need to charge it to be able to start it. There would usually be some of the related issues such as limp mode, but other than that, no problems so long as you can unlock the door with a key.
Mine is primarily a weekend camping rig, and we don’t go camping every weekend. To that effect I try and drive it once a week in to work to get everything up to temp, boil off any moisture in the fluids, and get everything rotating. Sometimes I’ll pop it in to 4 Low as I enter the parking lot just to move the linkage and get the transfer case operating in a different mode. I have a small battery drain issue that wouldn’t matter if I drove it every day or every few days but it’s just a bit too high for me to let it be for a week so I’ve installed a battery quick disconnect on the negative terminal and disconnect it if I know its going to sit for more than a few days (which is most of the time). My truck doesn’t sit in a good place for me to have a battery tender on it, which would be the ideal alternative.
The big downside is that I have to A) Change my settings in my aftermarket radio every time, B) Make sure I don’t forget to turn the HVAC back on (I just keep it in Celsius, for that worldly flare) and C) I’m probably suffering a little bit fuel economy wise as the computer doesn’t get a lot of time to “learn” before being disconnected.
Last year my D2 sat a lot. Around 3 weeks of sitting the battery would be pretty low. Now I put it on a solar charger when ever its sitting for 2 weeks. Fires right up and no low voltage issues.
I do have a dash cam that runs when the D2 is parked until it senses 12v. So that speeds up the voltage drop when sitting.
We've got a spare 04 that sits 90% of the time, garage kept. Usually drive it once every three or four week during nice weather months, ten miles, just to splash some oil around in the axles, transfer case, trans and engine and charge battery and get rust off rotors and exercise calipers. Four weeks seems to be about the max for sitting and mainaining enough battery to start...so...during winter months when it never leaves garage...charge battery once every four weeks.
