Condensation in headlamp assembly
Old Oct 28, 2005 | 01:00 PM
mcbenavidez's Avatar
Default Condensation in headlamp assembly
Could anyone tell me the best way to cure this? It's obviously not major, but I'd rather nip it before the cold Chicago winter. There are no cracks in the assembly.
thanks!
Old Oct 30, 2005 | 09:20 AM
DiscoMike's Avatar
Banned
Default RE: Condensation in headlamp assembly
The glass will have to be split from the headlamp unit, and resealed. Its not a hard job, just have to be very careful when breaking the seal between them that you dont crack the glass...
A bodyshop will be able to do it for you cheaply
Old Oct 31, 2005 | 03:15 AM
Nux's Avatar
Nux
Hi, recently I had this problem due to a pinhole chip in the glass.
The super easy way (the route I took) is to remove all your bulbs from the unit (H4/peanut) get a hair dryer and point it close to the H4's socket. let it blow on the medium warm setting for a while. should evaporate in less than 1/2hour. Of course I have no idea how much water you have in there. When I did it, I just pointed it down at the connector and walked away with it on for about 30 mins. Sealed the pin hole and it never came back. Also check to see if your bulb is missing it's O-ring.
The hard way, which gives you access to actually clean the glass is to separate the lens from the reflector body. Remove the bulbs , remove the light assembly, put it in your oven for about 20 mins with it preheated to about 300F, the lens and reflector will just separate like butter. This gives you a chance to clean out any deposits from the water. Of course, you have to get the right urethane sealant to put it together professionally.
Have fun!
Daniel
Old Dec 7, 2005 | 06:53 PM
billie's Avatar
I have the same problem - especially on the fog lights. I have a Discovery TD5 ES Auto (Sept 03)
ZB-30
Jul 26, 2012 12:57 PM
Tonga
Mar 28, 2011 10:40 AM
yvanjerome
Mar 19, 2010 01:53 PM
Chrisinhouston
Nov 9, 2009 01:37 PM
erapson12
Jul 23, 2009 09:25 AM
