Condensation on oil cap
Old Nov 2, 2011 | 09:04 AM
  #21
94svt50's Avatar
I just know at last oil change the cap was clean.
Old Nov 2, 2011 | 06:16 PM
  #22
94svt50's Avatar
So is it safe to assume this crud is related to weather and driving conditions for those several weeks of frequent short drives and not a headgasket issue?
Old Nov 2, 2011 | 07:27 PM
  #23
No that is not a safe assumption, Clear droplets are from the engine not warming up enough to burn of the internal moisture, custard, yellow build up is from coolant mixing with oil as from a leaking head gasket.
Old Nov 2, 2011 | 07:41 PM
  #24
94svt50's Avatar
If it was a head gasket wouldnt there be evidence of the crud on the dipstick as well? When I first took the cap off there was a lot of clear water on it couldnt that water sitting on the oily cap create this discoloration. The yellow was like a slimy film not like the whitish clumpy crud I had when I blew a headgasket on my mustang.
Old Nov 2, 2011 | 07:42 PM
  #25
After your head gasket change you should have changed the oil, I am going to assume the mechanic did that while he had the truck.
You should have changed the oil again about 500 miles later to make sure all of the crap from the gaskets was removed from the engine.
Personally I think you are fine.
Driving the truck the short trips during the week and then one long trip on the weekend like you are doing now is fine.
You have until February, thats enough time for a bad head gasket to show back up IF there is a pending problem.
Old Nov 2, 2011 | 07:53 PM
  #26
94svt50's Avatar
thanks for the reply. very true I do have some time. I have changed the oil about a half dozen times since the gasket change. I was trying to solve the rover tick with different weights of oil, but it made no difference but, at least the engine should be cleaner then what it was.
04BluDisco
Dec 16, 2009 01:30 PM
tsuami1
Jul 15, 2009 02:28 AM
thorogood32
Jun 26, 2007 09:13 PM
xadamx
Jun 12, 2007 10:01 PM
mcbenavidez
Dec 7, 2005 06:53 PM
