Condition of main bearings
Old Jul 4, 2024 | 12:35 AM
evil_goat's Avatar
Question Condition of main bearings
I am transplanting my 4.6L crank and pistons into a 4.0 engine from the junkyard. Extinct said that I could re-use my main bearings, but that was with only based off of two photos. I am posting more photos to further show the condition of the bearings. Can these still be re-used, or should I get new ones? Note that one of the bearings in the cap is pretty scratched up, and one of them in the block has a nick that is circled. Will moving bearings to the new block cause any problems with the seating?
Old Jul 4, 2024 | 10:21 AM
Richard Gallant's Avatar
I would replace them, they are a bit worn and you are already in a place to do them
Old Jul 4, 2024 | 10:44 AM
H Hill's Avatar
Agreed. You're in that far, replace them.
Old Jul 4, 2024 | 02:58 PM
JohnZo's Avatar
Agree with the previous 2, but if budget is really a problem, the bearings look fine to reuse. Just remember that gas will be over $80 per tank, by comparison, to go 300 miles or so. So, $80 worth of bearings is not a huge input in the long term.
Old Jul 5, 2024 | 10:52 AM
Extinct's Avatar
That top layer is only .013mm thick typically (ref: https://ozparts.eu/4B603H-20) and you have not even worn through it, waste of money in my opinion.
Old Jul 7, 2024 | 01:07 PM
evil_goat's Avatar
Will replacing them increase the chances of the crank grabbing on and spinning a bearing?
Old Jul 7, 2024 | 01:50 PM
Extinct's Avatar
Def not
Old Jul 8, 2024 | 08:43 PM
RA122125's Avatar
Banned
It is common knowledge within the Automotive field, that you Do not reuse bearings, ever. The reasons are many, and extremely well documented if folks care to look.
Bal D Correa
Sep 23, 2019 09:00 PM
Bal D Correa
Sep 23, 2019 08:58 PM
00&04 Disco
May 15, 2019 08:35 PM
Crunkgringo
Aug 20, 2018 11:38 AM
BCDisco2Lando
Jan 9, 2014 06:56 AM
