Confused about power steering fluid
Old May 5, 2015 | 08:37 AM
film842's Avatar
Default Confused about power steering fluid
Getting ready to replace my power steering fluid (02 Disco) and research on this forum gives conflicting advice. Some insist that ATF should or could be used and some say power steering fluid.
I've even been told in passing by a mechanic whom I trust to use ATF because "regular power steering fluid will rot out the seals." Never had a chance to ask him about that statement and as far as I know PS fluid is what's been in there for 146k.
I think I have to go with PS fluid (Lucas) since that's what Rave tells me to do. Am I missing anything obvious?
Old May 5, 2015 | 08:52 AM
dusty1's Avatar
I use regular lucas ps fluid with no issue. I use it in ace system too
Old May 5, 2015 | 12:17 PM
film842's Avatar
Just checked with my local O'Reillys and the're selling quarts of Lucas PS fluid for $23 each. Ouch.
According the high mileage sticky here, I'll need four quarts. Oh the pain.
Old May 6, 2015 | 06:52 AM
Lowest Bidder's Avatar
I used good ole Prestone power steering fluid at 24 canadian dollars a gallon. No issues after three years.
Old May 6, 2015 | 07:08 AM
CollieRover's Avatar
I used Valvoline with lucas additive.
Old May 6, 2015 | 02:57 PM
Big Jim Swade's Avatar
I went with the Prestone power steering fluid also. No issues.
Old May 6, 2015 | 03:12 PM
OffroadFrance's Avatar
ATF, same stuff 'cos they'll charge you more for PAS oil and it's the same. Ripoff oil companies like additives companies.
Old May 6, 2015 | 04:42 PM
OEMPartHaus.com's Avatar
Former Sponsor
My catalog is calling for this: PENTOSIN Hydraulic System Fluid 975 54001 348 | OEM Part Haus
Or this: FEBI Hydraulic System Fluid 975 54001 280 | OEM Part Haus
Old May 6, 2015 | 08:19 PM
Kenso's Avatar
Originally Posted by OEMPartHaus.com
I've been using Pentosin fluid, it seems to work really well. Pump runs a little quieter with it.
Old May 6, 2015 | 09:38 PM
bosshogt's Avatar
I use Royal Purple full synthetic Max Ez for the last 6 years and a half bottle of Lucas power steering stop leak. Its been great and does not wear out seals and hoses. You can find it locally @ O'Reilly Auto parts or Pepboys only.
I'm about to exchange the fluid and rebuild the power steering pump this weekend.
