Console trim removal
Old Jan 24, 2008 | 10:48 PM
sinebubble's Avatar
Default Console trim removal
My HSE with wood trim did not come with heated seat buttons. I recently bought the buttons and discovered (no pun intended) that I lacked holes for the buttons! If I remove the wood trim console, is there the equivalent of whatever comes in a Disco w/o the wood trim underneath? Is it worth it to find someone good with a dremel to create the holes in the existing wood trim (vs. finding another one for $300)? And any tips on how to remove the trim? The shifter seems to be the roadblock at the moment.
Old Jan 25, 2008 | 09:06 AM
okdiscoguy's Avatar
Default RE: Console trim removal
The panel should just pop out. Gently pry it out... You can get replacement panel without the wood for $12, or call ATB, they might have a wood one..
http://www.roverparts.com/Parts/BTR3655LNFG.cfm
they have one in black too...
http://www.roverparts.com/Parts/BTR3655PUYG.cfm
E-bay is a good source for stuff as well...
Old Jan 25, 2008 | 03:11 PM
sinebubble's Avatar
Thanks, but the problem is the console trim wood panel is all one piece from the buttons holes to the cigarette lighter. I have the black plastic switch panel with the buttons that you linked, but the wood panel doesn't have the holes, so I would have to either cut the wood part off where the black plastic switch panel would fit or remove the entire wood panel entirely. But then would I need the plastic rubber thing to fit on the console. Hm. Best bet would probably be to cut the wood panel where the plastic switch plate would go, but how to cut that thing while it's stuck to the console. Sheez.
Old Jan 25, 2008 | 04:24 PM
okdiscoguy's Avatar
my only suggestion for that is to take a piece of masking tape and draw out a line where you want to cut. Then take a dremel with a cut off wheel and go slow..... The tape should give you a good, clean cut....
I didn't realize the HSE trim went all the way through. eek.
Old Jan 25, 2008 | 07:31 PM
sinebubble's Avatar
Ah, that's where I figured this was going... I don't mind loosing the "wood" around the buttons, but the cutting part does worry me a bit. Hopefully the wood part pries off easily once I cut it. Anyway, I'll give it a whirl and post pictures. Thanks,
B
BTW, this is what the wood console trim part looks like:
Old Jan 25, 2008 | 08:35 PM
okdiscoguy's Avatar
before you cut, you may want to run by the dealer and ask them if they will help you out. They may even pull it for you if you give it to them to re-sell. Might be worth trying. I have a dealer that bends over backwards to make people happy. Might give it a shot....
Old Dec 11, 2009 | 02:07 AM
tastandish's Avatar
Did you ever get this figured out? I have the same problem and I am trying to decide what to do. Anyone else do this?
xhevi
Jan 17, 2019 01:31 PM
tturner
May 5, 2017 07:01 PM
kessragnell
Mar 1, 2012 08:51 AM
dansgt
Feb 20, 2012 08:56 PM
nevada ben
Sep 12, 2011 10:29 PM
