coolant boiling in overflow tank
Old Dec 12, 2007 | 02:54 PM
bigfun's Avatar
Default coolant boiling in overflow tank
I just purchased a 2001 Disc and noticed when looking under the hood that the coolant is bubling...boiling in the overflow tank>..? Is that normal?
thanks
Old Dec 12, 2007 | 03:35 PM
jdelp's Avatar
Default RE: coolant boiling in overflow tank
Short answer is no. What do you mean exactly? You can see bubbling w/ the system sealed and the truck running? Check your hoses coming into the coolant tank, may have an air leak. Temp needle steady?
Old Dec 12, 2007 | 03:47 PM
jkid's Avatar
Bubbling in the coolant is often an indication of a head gasket leak, I believe. Or possibly a bad radiator cap. I'm not saying that's what it is though.
I can't remember, but doesn't the reservoir have a small return hose to it (from the intake somewhere)?It could be that.
Old Dec 12, 2007 | 03:53 PM
jkid's Avatar
So how bad is it bubbling and can you tell where the bubbles are coming from?
Old Dec 12, 2007 | 04:18 PM
bigfun's Avatar
Bubbling while running...I'l check the cap and hoses. Head gasket worries me, is that common?Would a pressure test show a head gasket leak?
Thanks
Phil
Old Dec 12, 2007 | 04:40 PM
Stop driving the truck till you can line up someone to check it, you get it too hot and you'll loose the engine.
Any question call me.
303-862-7680
Colorado between 7 am and 8 pm
Old Dec 13, 2007 | 11:39 AM
bigfun's Avatar
Default RE: coolant boiling in overflow tank..all OK!
Thanks...the coolant was flowing in the tank, not boiling upon later inspection. Thanks again.
Phil
Old Dec 13, 2007 | 12:02 PM
Darover's Avatar
That's what I was gonna sayIts circulating, not boiling.
Old Dec 13, 2007 | 04:23 PM
Chrisinhouston's Avatar
This confused and concerned me also and the LR Disco is different from most cars in that it does not have a sealed radiator with a separate overflow reservoir but a combined radiator/reservoir. Unscew that cap while the engine is hot and you are in a world of hurt.
I also noticed that the PS pump resevoir has a boiling appearence when the engine is running.
Chris
ewatk
Jul 9, 2020 05:17 PM
Twncty2
Apr 21, 2013 08:01 PM
junya
Aug 12, 2011 08:24 PM
pompano
Nov 5, 2006 10:29 AM
