Coolant cap failure
That's part of the problem i guess is nothing else showed up other than i could smell anti freeze, popped hood and visually noticed coolant coming from cap. That's why i'm looking for pointers on what could have caused it so i can start trying to solve the issue. I have heat so i don't think it is an airlock but maybe? Something else with motor? Possible water pump? Was just hoping maybe someone else had this issue in the past and could give me a quick answer or direction to look. Not a mechanic, don't claim to be, just trying to learn more about the disco so i can work on simple things myself. Someone had mentioned the temp gauges are inaccurate, mine seems to go right to the middle after warm up and stays there, maybe it is getting hot and blowing the relief valve on cap? Not trying to **** anyone off just suffering landrover frustration!
Fern... look into getting an UltraGauge. You can mount it inside your truck as you see fit. It plugs into the OBD2 port under the dash and gives you real time measurements. Set engine temp as one of the main read outs. That will help you keep an eye on your temps. The gauge in the dash is extremely inaccurate.
Now, as far as your cap blowing off... I'm not sure why, other than too much pressure building up in your system. Like DR said, take it somewhere and get it pressure tested. That will get you started on what the issue is. It could be something simple, maybe something bigger.
Where are you getting the pressure caps from? If you are buying the wrong part, maybe that's the issue? There are a handful of suppliers that you can get parts from. Your local autozone/oreilly's/advanceauto places don't carry many parts for Land Rovers. And, if they do, the parts are usually remanufactured or cheap china crap.
