Coolant Change
Old Apr 26, 2009 | 02:19 PM
Night Train's Avatar
Unhappy Coolant Change
Ok so I guess it is possible that I am as look as dumb I are. I had today set aside to change my termostat and my coolant However, I can not find the block drain plug and only managed to swap out about 1 and a 1/2 gallons. I would appreciate the answers to a few questions.
1. Where is the drain plug - picture would be great
2. Should the vehicle be on ramps prior to draining
3.How much in US gallons should I expect to change after using the drain plug
4. Is the underbody cover needed or is there an easy way to remove it for service
Thank you for your responses
Spot On
Robert
Old Apr 26, 2009 | 02:37 PM
The drain plugs are nearly impossible to get to, they are shown on the Rave if you have one.
Truthfully, I wouldn't loose too much sleep over not getting it all out.
Old Apr 26, 2009 | 04:34 PM
llPANCHOll's Avatar
If you really want to flush it, just run it for a while and then drain and fill it again..
I filled mine with water and let it go through a few heat cycles, drained and refilled with water and did it again, then I filled with coolant.. Of course I had to adjust for the water in the system to acheive a 50/50 mix, but it was pretty simple math.
Old Apr 26, 2009 | 06:19 PM
Do what he said, buy one gallon of full strenght colant and one gallon of the 50/50 premixed.
Dont worry about the block drains.
Depending on if its a DI or DII, DI's take 3 gallons and DII's roughly 2.
Old Apr 26, 2009 | 07:08 PM
Cool Beans - thanks guys
I dont have the rave and have tried to download it from the link on ak rovers signature but it doesnt work. Where else can I get it.
I had it before my computer cXXped out (
Old Apr 26, 2009 | 07:30 PM
llPANCHOll's Avatar
http://www.landroverresource.com/
You tried to download it there right..
It wont work for you or it wont download??
Try updating your Adobe software and see if it works then..
mln01
Jun 12, 2014 07:23 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
Disco Alan
May 11, 2009 04:15 PM
