Coolant change?! One unanswered question
Old Oct 31, 2012 | 01:31 PM
AwannaD2's Avatar
Default Coolant change?! One unanswered question
Im slowly checking off my list for my coolant change as do research and Ive settled on a method for flushing it, which will be a repeated drain and fill with distilled water then filling with PEAK (OAC) 50/50. But there is one question I havent found an answer for.
After the final drain, how much distilled water remains in the block?
Im not super concerned about not have exactly a 50/50 mix but I dont want to be way off either. Thanks
Old Oct 31, 2012 | 02:11 PM
Depends on how well you drain it. I would measure how much water you drain out and subtract that from what the system holds.
Are you alos replacing the t/stat and the pressure cap. how many miles on the engine and where is your bleed screw located?
Old Oct 31, 2012 | 02:34 PM
AwannaD2's Avatar
Thanks Mike for the prompt response.
I have a Motorad 180 in the mail and I will pick up a cap as well. My 03 Disco has 85k miles on it and the bleed screw is right on top of the T fitting on the rad top tube.
Old Oct 31, 2012 | 03:51 PM
If you are worried about how much distilled will be left in the engine, buy one bottle of straight coolant which you will add first and a bottle of 50/50 to top it off .
Old Oct 31, 2012 | 06:17 PM
jfall's Avatar
get a specific gravity gauge for $5 at the autoparts store.
If it is protecting down to -20 or so you are fine.
Old Oct 31, 2012 | 07:58 PM
There will be maybe a pint of straight water left in the block and heater core.
Not enough to make a difference for 95% of the people out there.
Old Nov 1, 2012 | 01:26 PM
AwannaD2's Avatar
good to know. Thanks for the help
bootzilla
Oct 22, 2012 01:14 PM
disconewb
Dec 14, 2011 06:32 PM
collin Barrows
Aug 28, 2011 07:13 AM
Disco Alan
May 11, 2009 04:15 PM
