Coolant disappearing
Old Oct 1, 2020 | 12:12 PM
  #21
Frank Gordella's Avatar
I have the inline t stat mod.
Old Oct 1, 2020 | 12:55 PM
  #22
zuke's Avatar
I hate to say it but if you aren't seeing puddles after parking then it's probably a HG job in your future.
Old Oct 1, 2020 | 01:26 PM
  #23
Harvlr's Avatar
This spring I had an internal coolant leak, which I incorrectly diagnosed as HG's. I should have investigated further, but I removed the heads before I figured out that wasn't the issue. A pressure test would have helped me diagnose it. Obviously I now had to replace the HG's. The real issue was a bad gasket under the timing cover which allowed the coolant pump to pump coolant directly into the chain area, and down into the sump. After replacing it i have been driving it now for several months with no leaks. One tell tale sign I should have clued into was the grey sludge on the oil filler cap.
2001 D2 4.0
Old Oct 1, 2020 | 01:53 PM
  #24
The real mystery here is that the coolant goes down in the ET, then returns. There are no puddles, milky oil, white smoke...nothing.
I plan on pressure testing it this weekend.
When I do, what’s the procedure for the overflow tube. That’s gotta be out of the equation for pressure testing, right?
Old Oct 1, 2020 | 02:07 PM
  #25
Harvlr's Avatar
What would happen if the small 5/16" hose from the top of the Rad to the ET was plugged?
Old Oct 1, 2020 | 02:53 PM
  #26
Dave03S's Avatar
how did you fill it through the bleed screw if you have the inline mod? Doesn't that eliminate the T and the bleeder screw.
Old Oct 1, 2020 | 03:28 PM
  #27
Richard Gallant's Avatar
@Dave03S Normally yes but there mods that add an inline bleed point
Old Oct 1, 2020 | 04:28 PM
  #28
Old Oct 1, 2020 | 07:29 PM
  #29
shanechevelle's Avatar
Park it on a hill!
Old Nov 11, 2020 | 07:20 PM
  #30
My apologies for the delay on getting back on this thread. Life’s been a real 2020 lately.
This problem seems to just more and more weird. I did the pressure test. Pressure held solid for an hour. The engine temps are still erratic which, as previously mentioned, would indicate trapped air. I have bled the system repeatedly. On a hill, on ramps, expansion tank lifted...all the things. Anyone have any suggestions before I take it to the shop?
