Coolant help change. Need help by the end of the day
Hey guys. I was tackling the hose change and coolant flush on my d2 today and I ran into a problem. I flushed the engine/radiator/heater core with water from a garden hose and no I am putting everything back. Here is where I am stuck. If I put everything back and then fill her up with the 50/50 peak global that I have, wouldn't there be an excess of water in the system. There is no way for me to remove the water that is left in the system from the hose flush. Perhaps I should blow it out with my shop vac? Please help. Thanks
Stand on the bumper and bounce the truck you will get maybe a cup of water out.
There is maybe 1.5 cups of water left in the system after you flushed with the garden hose, maybe.
After you get the system all nice and full and bled just check the freeze/boil protection with a coolant tester, you will see that its fine.
