Coolant Leak
Coolant Leak
Hi everyone. I know this is the lazy-man's way, but it's cold as a witches freezer out there, and thought maybe you guys could save me some time on this one.
I attached a picture so you can see, but obviously I have a coolant leak somewhere. Has anyone seen this kind of splatter/spray before, and have an idea of what the issue could be? There hasn't been any over heating, and I haven't overfilled the reservoir, so I don't think it's overflow. It almost looks like it hit the fan and sprayed. Maybe the radiator?
Thanks! Nick
Thanks! Nick
So I took the bleed screw off and inspected it and the o-ring. Both seem fine, clean and free of cracks/warping. But when I put it back in and fired her up, I can definitely see the coolant spouting out right from the screw. I basically hand tightened it and then a 1/4 turn with the screw driver, as I've read horror stories of them cracking and falling through. Have I just not tightened it enough/not found the real issue, or in your experience do these screws/o-rings fail without visible damage? Thanks again guys!
End that headache and grab a Brass bleeder > https://www.ebay.com/itm/Land-Rover-...4383.l4275.c10
