Coolant Leak
Old Dec 13, 2017 | 10:04 AM
nmacej's Avatar
Default Coolant Leak
Hi everyone. I know this is the lazy-man's way, but it's cold as a witches freezer out there, and thought maybe you guys could save me some time on this one.
I attached a picture so you can see, but obviously I have a coolant leak somewhere. Has anyone seen this kind of splatter/spray before, and have an idea of what the issue could be? There hasn't been any over heating, and I haven't overfilled the reservoir, so I don't think it's overflow. It almost looks like it hit the fan and sprayed. Maybe the radiator?
Thanks! Nick
Old Dec 13, 2017 | 10:17 AM
mollusc's Avatar
Looks like it might have come from the bleed screw or one of the legs of the T.
Old Dec 13, 2017 | 10:27 AM
OverRover's Avatar
I would agree. Check the O ring in the bleeder screw, and also look for a crack in the Tee .
Old Dec 13, 2017 | 10:31 AM
robert.juric's Avatar
Yea, I'd grab a few replacement bleeder screws. Always good to have on-hand.
Old Dec 13, 2017 | 10:33 AM
nmacej's Avatar
Thanks, Mollusc. I'll clean her up and see if I can spot it around there. That would be better news than the radiator I suppose.
Old Dec 13, 2017 | 10:55 AM
nmacej's Avatar
So I took the bleed screw off and inspected it and the o-ring. Both seem fine, clean and free of cracks/warping. But when I put it back in and fired her up, I can definitely see the coolant spouting out right from the screw. I basically hand tightened it and then a 1/4 turn with the screw driver, as I've read horror stories of them cracking and falling through. Have I just not tightened it enough/not found the real issue, or in your experience do these screws/o-rings fail without visible damage? Thanks again guys!
Old Dec 13, 2017 | 11:01 AM
Davis31052's Avatar
Make sure that the plastic hose "T" that the plug screws into, isn't cracked.
Old Dec 13, 2017 | 11:04 AM
OverRover's Avatar
Those plastic bleed screws $UCK!
End that headache and grab a Brass bleeder > https://www.ebay.com/itm/Land-Rover-...4383.l4275.c10
Old Dec 13, 2017 | 11:07 AM
nmacej's Avatar
The T itself looks okay to me.
Old Dec 13, 2017 | 11:47 AM
LR03NJ's Avatar
If you need something for emergency, temporary or permanent, you ca run to home depot and get a copper Tee
