coolant leak..head gasket?
I borrowed/never returned a pressure tester from advance auto parts. They charged me $170 to borrow it, but will give it all back when returned. I don't even think there's a time limit (not sure) but, they also told me I could keep it if I want. I don't have it right in front of me but I'm sure it's got a connection for your cap. It's got about 50 different ones. That way you will definitely have the exact right cap to check your system and when you return it you get all of your money back.
Yes a cavity in the lower manifold collects coolant flow from the engine. The coolant outlet pipe attached to the front of the manifold allows coolant to flow through the cavity in the casting to the radiator top hose. A smaller port in the manifold also allows coolant to flow from the cavity to the heater core. The Engine Coolant Temperature (ECT) sensor is attached to a port in the front manifold.
RAVE manual 30-2-5
RAVE manual 30-2-5
Anyway, that would be a great time to do the plug wires if you haven't done them yet. Otherwise, that's it. No other gaskets in there that would need to be done. Unless you can visibly SEE something leaking there's nothing else you NEED to do, just a few wire connections and some hoses, vacuum lines, that kind of thing.
Make sure you get the end seals for the valley pan, I think they are seperate parts. I believe there are two, one on each end, front and rear. Basically just two pieces of rubber if I remember correctly.
Recomend confirming intake gasket failure before embarking. Recommend downloading the RAVE workshop manual.
Possible source I am familiar with. There may be others.
Atlantic British
6 Enterprise Avenue
Clifton Park, NY12065
800 533-2210
Internet http://www.roverparts.com/
Bosch intake gasket kit
http://www.roverparts.com/Parts/9218B.cfm
Valve cover kit
http://www.roverparts.com/Parts/VCGK.cfm
Atlantic British
6 Enterprise Avenue
800 533-2210
Valve cover kit
