Coolant Leak- Radiator hose questions
Old Mar 9, 2011 | 05:21 PM
dida's Avatar
4wd High
Default Coolant Leak- Radiator hose questions
OK, just got this 2001 disco running, replaced the head gaskets and runs great.
Except....
I have two leaks.
One is the ACE, trying to pinpoint. Work in progress.
The other, developed today, is a coolant leak. I traced it back to the top radiator hose- the one with a round/hole/fitting in it. It sits atop the fan shroud. When I squeeze the hose, coolant comes out of that little hole/vent/wetf it is. When the engine is running, coolant mists out of it.
What is this for? Why is there a hole there for God sakes.
Is this simply a matter of changing the hose?
everyday is something new.... God save the queen- she needs it.
Thanks in advance for the input.
Old Mar 9, 2011 | 05:30 PM
dida's Avatar
4wd High
Also, there is no screw or cap on that threaded hole on the top radiator hose.
Old Mar 9, 2011 | 05:33 PM
Bundu's Avatar
Banned
That is the bleeding screw for the coolant system, you have the old style. The newer style replaced that with a bleeding screw in the T in the upper hoses.
Old Mar 9, 2011 | 05:46 PM
dida's Avatar
4wd High
Thanks Bundu... looked it up and see what you mean. Looks like I can buy the screw for $6 or buy the hose for $60....
FWIW... the screw is missing. Cant believe the mechanic shop would send me on my way with new head gaskets and no screw in that top hose. Seems like a recipe for disaster or sabotage or carelessness. I mean, its supposed to have a screw there- right.
Would you guess its been leaking since i picked up from the shop- a week ago and 100 miles of driving. Thankfully no overheat....
Old Mar 9, 2011 | 05:55 PM
Snafu / Disco Fries's Avatar
Yes...that is the bleeder. Big mistake on their part!
Old Mar 9, 2011 | 07:44 PM
photocrimes's Avatar
Check with the shop, my guess is they bled the system and forgot to put it back on. I'm not sure how, but I don't see you going too far without it.
ZMonet
Jun 24, 2016 04:00 PM
samue23
Mar 1, 2012 05:49 AM
werldcup
Mar 14, 2007 05:05 PM
