Coolant Leak From Rear of Engine
Hi guys,
Quick question about a rear engine coolant leak.
I have a small coolant leak. It drips down on the front drive shaft, but I think it is coming from the rear of the engine. The vavle cover gaskets are new. So I'm thinking valley pan or heads. My question is this:
When I do a pressure test, how can you see behind the engine to tell if it is valley pan or heads?
Thanks!
Thanks!
The head gaskets were replaced at 19k because of sticking valves, not because it was leaking. I got the truck with about 30k miles on it and I got the service records from the dealer.
I'm heading in for a pressure test in a few minutes. Will let you all know what we find! I just wanted to know what to look for when I take it in.
Thanks!
Thanks!
Pressure test was inconclusive. But, the mechanic spend a good 15 minutes watching the passenger side with a mirror and he thinks it's the head gasket. He saw a small drop come out behind the engine by the exhaust manifold. He quoted me $1500. He also said that when he gets the intake off, it may turn out to be the intake gasket instead.
Now I'm just pondering whether I want to tackle this myself or not...
I had the same problem with my 03... I did the work myself and took a couple days... I found the back 2 bolts finger tight that held lower intake on and that was my coolant leak... went ahead and replaced valley pan gasket along with new valve cover gaskets and minor other gaskets that came with the headset from Atlantic British...
