Coolant Level
Old Aug 21, 2007 | 05:42 PM
bigugly82's Avatar
Default Coolant Level
I look to be about an inch below the correct coolant level. Can I just top off or should I flush and refill totally?
And what recommend fluids?
-Ugly
Old Aug 21, 2007 | 06:24 PM
Default RE: Coolant Level
Are you having to add coolant, loosing any? If not fill your coolant bottle to the top one morning before you start your truck, let the truck do the rest.
Mine stays right below the cap and never moves.
Old Aug 21, 2007 | 10:51 PM
bigugly82's Avatar
I'm not sure what brand to coolant is being run, I assume whatever the dealer put in. Is it O.K. to mix different brands?
Thanks
Old Aug 22, 2007 | 07:39 AM
bigugly82's Avatar
Default Topping off Coolant
Is it O.K. to mix different brands of coolants?
Old Aug 22, 2007 | 07:57 AM
Default RE: Topping off Coolant
No, you can not mix them, this will cause head gasket issues. What color is your coolant, should be an orange color, not yellow or green.
Old Aug 22, 2007 | 08:04 AM
bigugly82's Avatar
GREAT! I put in some yellow to top off. It had orange in it. Looks like I'm draining today. What kind should I put in now since I need to drain it? Chemical flush as well? And is this a morning job of can it be done warm?
thanks
d2luvr
Jul 21, 2009 10:37 PM
satcal0
May 3, 2009 01:54 PM
ryanljcom
Sep 18, 2008 12:06 PM
MikeLi
Sep 18, 2008 10:33 AM
ferrelltodd
Dec 18, 2005 03:33 PM
