Coolant level low...cant see a leak
Old Jul 14, 2011 | 06:51 AM
mwood2121's Avatar
Default Coolant level low...cant see a leak
Morning Ladies (if any) and gents. Have a coolant leak somewhere and I cant see where it is leaking from. Is that normally the head gasket? Not mechanically inclined here so any help would be appreciated. Its a 02 disco SE II with 100k on it.
Old Jul 14, 2011 | 07:02 AM
drowssap's Avatar
the first thing you will want to do it preasure test your cooling system, your problem could be as simple as a loose hose clamp. You can borrow a preasure tester from autozone or advanced and do it yourself. if you are not so inclined any local gas station/garage should be able to do it for you quite cheaply. After that get back to us, you dont want to jump right to head gaskets until you have ruled everything else out first.
Old Jul 14, 2011 | 07:39 AM
Since you are not mechanical, go have it pressure tested, not at a dealer and get back to us with what they find and the estimate so we can help you and don't delay, you may have some expensive issues going on.
ZMonet
Jun 24, 2016 04:00 PM
gillart
Jan 22, 2015 03:35 PM
Ajibola
Mar 27, 2012 07:34 AM
Batten
Jan 5, 2011 06:33 PM
MikeLi
Sep 18, 2008 10:33 AM
