Coolant overflow snapped
Old May 17, 2024 | 09:48 PM
WoldD2's Avatar
Default Coolant overflow snapped
Hey all, So on my discovery I was taking off the upper rad hose and as i was putting it back on I accidently snapped the Coolant overflow line, I tried using epoxy and it worked for a while, What would yall suggest I could do to fix it without having to replace the radiator?
Old May 18, 2024 | 10:16 AM
Harvlr's Avatar
Replacing the radiator is the right way to fix it. Having said that, I drilled mine out and tapped a 1/8 npt and installed a nipple. I’ve been using it for a few years like that but I really need to replace the rad as it’s probably a ticking time bomb.
Old May 18, 2024 | 01:24 PM
jastutte's Avatar
if that plastic nipple was brittle enough to snap, then the rest likely are as well. i'd just replace the radiator.
Old May 18, 2024 | 03:32 PM
Tony Luna's Avatar
A while back ago I drilled and tapped the hole where the nipple broke off and used 1/4” threaded barb and epoxied it in.
Old May 18, 2024 | 04:01 PM
WoldD2's Avatar
Yeah I figured id try to tap it out, Thank you!
Old May 18, 2024 | 04:02 PM
WoldD2's Avatar
You're right, But The radiator is from 2015 but Its a cheaper off brand part.
Old May 27, 2024 | 12:17 AM
Rover_Hokie's Avatar
I put a piece of gas line on the plastic stub that was left at the radiator and ran it all the way to the overflow bottle. No more plastic hose!
me 2
Jan 8, 2022 06:26 PM
discorey
Nov 27, 2014 12:47 AM
samue23
Mar 1, 2012 05:49 AM
MaverickTye
Freelander
Jun 2, 2010 11:59 AM
Evian
Sep 10, 2005 01:39 AM
