What is the proper way of refilling the radiator after flushing it out?
Old Aug 24, 2005 | 08:44 PM
Evian's Avatar
Default What is the proper way of refilling the radiator after flushing it out?
I removed all the coolant in my radiator by removing the bottom hose. I added coolant to the plastic nut located on the left side of the radiator. I also added coolant to my coolant reservior tank. The problem is that it is leaking out of the reservior tank and the temp is raising after driving it for 25-30 minutes. It doesn't go into the red but it gets close. What did I do wrong? Is there a certain procedure I was suppose to do when one removes all the coolant by flushing it out? What is that metal hose with a similar plastic nut for? How do I insure not leaving air in the system? I own a 1992 Range Rover. Thanks and keep Roving!
Old Sep 10, 2005 | 01:39 AM
modyfyit's Avatar
Default RE: What is the proper way of refilling the radiator after flushing it out?
fill up your radiator and keep your overflow cap OFF, run the car and add coolant to your overflow do this for a while and the air will burp itself out.. that is your problem
Chrisinhouston
Oct 18, 2013 01:19 PM
LADisco2
Sep 23, 2013 02:31 PM
innzane
Jun 20, 2012 05:39 PM
458steve
Dec 23, 2010 10:54 PM
bangkuaidiscovery04
Oct 12, 2010 05:10 AM
