Coolant problems
And thanks for the pointer, Rob; it didn't occur to me that it doesn't really matter *where* in the coolant loop one applies the pressure; i was fixated -- as I suspect many people are -- on the cap.
ok, what?
can we recap this for me cuz I'm getting lost. My rover just started shooting (and I mean shooting) coolant out of that thing under the throttle body too. Never noticed a coolant issue befor last night when I was suddenly out (temp didn't get so bad that the light came on but she was running hot when I noticed the problem. Hope she's ok) what is going on in there and how do I correct it?
also, any other things I should be looking for? Would this indicate any larger problems?
thanks!
thanks!
Get this and fix it
http://www.roverparts.com/Parts/MGM000010KG.cfm
Also check the hoses that attach to the TB heater, they get brittle and brake.
Hi all,
I'm new to this forum, so hello al and pleasure meeting.
Now let’s get back to the top at hand. I have Land DII and I seem to be experiencing the same problem as the thread starter. I had my land rover since 2004 and it has only 86,546 miles on it. About a year ago it started having coolant leaking coming from the driver side of the engine and the machines told me (after taking couple hundreds from) it was not that of big deal. I changed the water pump, steering pump and they put some liquid to shut the hole where the coolant was leaking from (Top kill, like PB oil leak).
My check engine and SRS comes on for weeks and then disappears.
I so frustrated now I hate land rover, which were once my dream cars.
Any suggestions are greatly appreciated.
By the way I live in Columbus, Ohio and any reference to great mechanics is also welcomes.
[quote=Somal;199278]Hi all,
you hate landrovers now cause your mechanic did a texporary fix and now its broke.if you didnt do the headgaskets yet you probley should.
You talk to machines? I've heard of people talking to animals.
Anyway, you got screwed, that coolant leak is a big deal and you most probably need a head gasket job, it is only going to get worse. That stuff they put in to stop the leak will not fix it and will most probably end up clogging your radiator.
