Coolant problems
Old Sep 15, 2010 | 10:53 PM
NiteTrain's Avatar
did your mechanic fix that throttle body leak? If not i would start there, you can just block it off, coolant to the throttle body isn't necessary. Yes, auto zone has loaner coolant pressure tester..but I don't think it will work with our rover radiators.
Old Sep 16, 2010 | 08:58 AM
If you want to verify the leak, don't waste your time and money on dye, just do a pressure test.
Old Sep 16, 2010 | 10:42 AM
yloDiscoII's Avatar
https://landroverforums.com/forum/sh...ressure+tester
Old Sep 16, 2010 | 11:14 PM
Baylink's Avatar
He did indeed; the plate was corroded to the leaking point, so he replaced it. The top of the engine doesn't appear to be wet, so far as I can see.
And thanks for the pointer, Rob; it didn't occur to me that it doesn't really matter *where* in the coolant loop one applies the pressure; i was fixated -- as I suspect many people are -- on the cap.
Old Sep 17, 2010 | 07:26 AM
NickMcAFP's Avatar
Default ok, what?
can we recap this for me cuz I'm getting lost. My rover just started shooting (and I mean shooting) coolant out of that thing under the throttle body too. Never noticed a coolant issue befor last night when I was suddenly out (temp didn't get so bad that the light came on but she was running hot when I noticed the problem. Hope she's ok) what is going on in there and how do I correct it?
also, any other things I should be looking for? Would this indicate any larger problems?
thanks!
Old Sep 17, 2010 | 08:25 AM
Bundu's Avatar
Banned
Get this and fix it
http://www.roverparts.com/Parts/MGM000010KG.cfm
Also check the hoses that attach to the TB heater, they get brittle and brake.
Old Sep 20, 2010 | 09:38 AM
Somal's Avatar
4th Gear
Hi all,
I'm new to this forum, so hello al and pleasure meeting.
Now let’s get back to the top at hand. I have Land DII and I seem to be experiencing the same problem as the thread starter. I had my land rover since 2004 and it has only 86,546 miles on it. About a year ago it started having coolant leaking coming from the driver side of the engine and the machines told me (after taking couple hundreds from) it was not that of big deal. I changed the water pump, steering pump and they put some liquid to shut the hole where the coolant was leaking from (Top kill, like PB oil leak).
My check engine and SRS comes on for weeks and then disappears.
I so frustrated now I hate land rover, which were once my dream cars.
Any suggestions are greatly appreciated.
By the way I live in Columbus, Ohio and any reference to great mechanics is also welcomes.
Old Sep 20, 2010 | 10:18 AM
bmw zhp's Avatar
Thumbs down
[quote=Somal;199278]Hi all,
you hate landrovers now cause your mechanic did a texporary fix and now its broke.if you didnt do the headgaskets yet you probley should.
Old Sep 20, 2010 | 10:20 AM
Bundu's Avatar
Banned
You talk to machines? I've heard of people talking to animals.
Anyway, you got screwed, that coolant leak is a big deal and you most probably need a head gasket job, it is only going to get worse. That stuff they put in to stop the leak will not fix it and will most probably end up clogging your radiator.
Old Sep 20, 2010 | 12:11 PM
Somal's Avatar
4th Gear
Thanks Bundu and BMW ZHP.
By the way it drives smooth and there are no other problem, except when I park and come back for it couple minutes later there is pool of coolant under neath it.
Someone mentioned "Head Gasket", how much does it take to chnage it including the part.
