Coolant Reservoir Field Repair
Old May 17, 2014 | 09:33 PM
mln01's Avatar
I've had a slow leak from the coolant reservoir side of the engine bay that I thought was a failed cap, but late yesterday it hemorrhaged to reveal it was from a crack near the base of the nipple on the bottom of the tank where the line to the throttle bottle heater connects.
The truck was only a little under three miles from home so to get it home I did what I did when the bleed screw blew out of the original top radiator hose a few years ago; I broke off the nipple and crammed a golf tee in the hole, then held it in place with a nice duct tape wrap, refilled and drove home after also plugging the throttle body line with a short 5/16 bolt and the hose clamp. I left the cap off because the last thing I wanted was pressure in the system that might force out the golf tee. But that wasn't the real field repair.
This morning I removed the reservoir, flipped it over and filed down the stub to be reasonably flat. Then I found a screw that fit the hole (#10x¾) and after testing it for a snug but not too tight fit wrapped it in Teflon tape and installed it in the hole. The reservoir shell and the stub gave me perhaps 3/8 to 7/16 of thickness for the threads to grab. Worked like a charm, and after driving around for a while this afternoon there’s no sign of a leak.
I’'ll order a new tank Monday but this technique could keep some other DII or P38 on the road someday.
Attached Thumbnails Coolant Reservoir Field Repair-photo-1-1-.jpg   Coolant Reservoir Field Repair-photo-2-1-.jpg   Coolant Reservoir Field Repair-photo-3.jpg   Coolant Reservoir Field Repair-photo-4.jpg
Old Jul 25, 2016 | 02:20 AM
Mskembo's Avatar
Any adverse reactions to that? My throttle heater is leaking and I need to replace it... Eventually.
Old Jul 25, 2016 | 04:35 AM
mln01's Avatar
I don't understand the question. Adverse reaction to what, the screw in the bottom of the tank or disconnecting the throttle body heater circuit?
Old Jul 28, 2016 | 10:03 AM
Mskembo's Avatar
Disconnecting the throttle body heater circuit. The answer is "No issues", I actually know the answer now, but didn't when I asked the question.
Old Jul 28, 2016 | 02:45 PM
mln01's Avatar
Yep, the TBH circuit exists unto itself. I guess the reason some people try to connect the two disconnected hoses at the TBH is that they've not really looked at the cooling system diagram. Just plug 'em.
Old Nov 22, 2016 | 07:38 PM
naivedisco2's Avatar
Thank you!!!! Reservoir nipple broke on my way to work, had to get home. Thankfully had the supplies to wing it like you suggested. New reservoir on order.
OffroadFrance
Off Topic
Jun 15, 2015 02:36 AM
yloDiscoII
Jul 23, 2011 03:47 PM
Kraftyz51
Sep 9, 2007 08:37 AM
