Coolant squirting from block.
Old Nov 3, 2016 | 09:58 PM
LR03NJ's Avatar
Default Coolant squirting from block.
Hi guys. Got major problem here and just wondering if there is a fix. My disco had power steering leak. Then i replaced the pump. After fix, coolant started to squirt right behind the pump mount and its coming from the block. Is there a possible fix? What to do. Thanks
Here is the video.
https://vimeo.com/190196254
Old Nov 3, 2016 | 10:07 PM
Red5's Avatar
I think most here will agree that what you have there is a major head gasket leak. The fix is to replace it, actually replace both while you are in there. You're not going to want to drive it until it's sealed up tight again.
Weird that is started only after you replaced the PAS pump. Maybe it was on the ragged edge of failure and pulling the mounting bolts caused it to finally break free.
Old Nov 3, 2016 | 10:41 PM
LR03NJ's Avatar
Thanks Red5,
I have been using 1 litre of steering fluid a day for a week and a half until I got the part. Then this happened. Oh, well. So far, Im getting used to fixing this disco all the time now.
If a leak like that happened due to gasket failure, any possibility that I badly damaged the engine? I started the engine to bleed the steering fluid, then after 10 minutes, it started squirting, then I turn off engine immediately.
I took all the parts out again to check where the leak is coming from.
Old Nov 4, 2016 | 03:48 AM
The Deputy's Avatar
Default Head gasket
Man, that stinks. Make a repair...and another one immediately pops up. What type of anti-freeze were you using?
You probably didn't do any harm to the engine, since you only ran it like that for a few minutes.
Good luck, with the repair.
Brian.
Old Nov 4, 2016 | 08:22 AM
chubbs878's Avatar
is this the same truck with ZERO compression across all cylinders that you posted about the other day? Don't tell me this is your 2nd truck that just $hit the bed...
Old Nov 4, 2016 | 09:15 AM
LR03NJ's Avatar
unfortunately this is the working disco that got messed up. Im with the other right now waiting for AAA to tow to another shop which this rapair shop said zero compression. Sending it now to a land rover mechanic to get it started. Worse, its weekend and cant find a rental car. I managed to rent one from a used car dealer with a beatup compact car.
Well, last night I purchased the head gasket kit for the leaking disco. I might do it myself. I guess im half way removing all the parts anyway.
Old Nov 4, 2016 | 09:18 AM
LR03NJ's Avatar
Brian.
Thanks Brian,
Ordered the part last night and would probably do it myself. Any special tools needed? Btw, i use Peak 50/50 green the blue container with yellow cap.
Old Nov 4, 2016 | 09:52 AM
Red5's Avatar
Torque wrench at least. The rest is just ratchet stuff.
You may also need new head bolts (or studs if you go that route). I have re-used TTY bolts on other engines without issue but the Bosch engine may be less forgiving. I have not personally had the heads off of mine.
Old Nov 4, 2016 | 12:10 PM
squirt's Avatar
Whoa... how did a huge leak like that just show up after replacing the p/s pump? Who did the work? Judging by the cleanliness of the area, it looks like someone put a lot of effort into cleaning it up. Was the gasket damaged in the process? (used a pick or something?)
Old Nov 4, 2016 | 01:11 PM
LR03NJ's Avatar
Actually, I did the p/s pump myself. Lol! Nothing close to damaging the gasket during the process. I guess my disco was just showing off. Does not want to get fixed. Its like a dog making its territory everywhere it parked. In leas than a week, this is how much fluiid it used until i got the new part. Fluid used less than a week.
