Coolant temperature
Old Feb 12, 2018 | 09:49 PM
Speedsterguy's Avatar
Pull the water pump, see if it has a plastic impeller if it does replace the pump. Plastic impellers will fail and slip on the shaft and cause the pump not to work well enough to cool the engine. I see it in several makes including land rovers
Old Feb 14, 2018 | 06:42 PM
old gold's Avatar
Update: Borrowed thermal camera
Ran truck up to 210 F
Top of thermostat ~190 F
Bottom Cold
Radiator cold
Too bad I ordered a radiator yesterday ($60 ebay special)
Looks like I will order a 180F LR thermostat
Old Feb 14, 2018 | 06:43 PM
old gold's Avatar
Sorry Speedster, to answer your question the water pump had a metal impeller.
Old Feb 14, 2018 | 07:06 PM
Best4x4's Avatar
Was this an OEM 180F you have in there currently? Light Grey color? Or was it black 180F Britpart unit? I’ve had great sucess with both & have actually switched to using the britpart unit more vs the LR OEM 180F.
Old Feb 15, 2018 | 09:11 PM
old gold's Avatar
Update:
Borrowed a thermal camera
Ran the truck up to ~210 F
Top of thermostat ~160 F
Bottom of Thermostat and radiator cold.
Spoke with Lucky8
They gave me credit for the bad T-stat and shipped me a Genuine 180F today.
I had already ordered a $60 E-bay radiator.
I'll install it when the weather gets a little warmer and change to green AF at the same time.
Also purchased a $12 IR Temp gun-good tip, thanks.
Old Feb 16, 2018 | 02:15 AM
shanechevelle's Avatar
Do you have the plastic t fitting with the bleeder over the alternator or the hose with the bleeder over the radiator?
Old Feb 16, 2018 | 09:13 PM
old gold's Avatar
The bad T-stat currently installed is an $18 All Makes P.O.S
180 F OEM on the way.
I have the plastic Tee with the bleeder screw on the truck
Old Feb 17, 2018 | 09:27 PM
uvodee's Avatar
my 2001 disco 2 most likely needs HG replaced, i have made an appointment with BIGGS, WA but that is in 10 days from now. I had already bought a Low Temp T( i think, it is the black version) from Lucky8 so i installed it today ----- i am getting good at bleeding the circuit LOL
Temp now has gone down
from 210 running to 187-189 and idling from 226 to 202
i don't know what else to say ... the old T had 4 holes just as the new one. i did see something that looks like a very small piece of cotton cloth or so in the old thermostat
if anyone else is saying to me that their coolant temp is too high on their Disco then i say buy the low temp T not too expensive and on mine it was miraculous
Old Feb 17, 2018 | 11:16 PM
Why do you say it needs the gaskets replaced?
Old Feb 17, 2018 | 11:36 PM
longtallsally's Avatar
If the motor is up to temp and the radiator is cold, there’s your answer.
Another thing is to check the fan clutch- if you rev the motor, the temp should drop.
