coolant temperature readings, to high?
And drowssap, my condenser fan does work as I can hear it when it comes on. I thought it comes on a 212F and turns off when the temp is back to 200F but I'm not really sure. I sometimes get to 215 on a warm sunny day at a stop light. It is black so the hood is untouchable even on some colder days. Cruising around I am usually at 208. This is why I plan to switch to the 180 stat in the near future.
I went nuts on temperatures last year. It started with what I thought were high temperatures but it had probably always been that way I just finally watched it change on my code reader. I did have some engine ruining spikes but that was after I started work and my own fault (air in the system and a blocked radiator due to the electric fan I tried). I got a new radiator, I flushed the block, I got an electric fan (which is now on my garage floor), I got a 180 degree soft spring thermostat, I got a new water pump, and I did the inline thermostat mod. The only thing that made a huge difference was the inline thermostat. And by huge I mean lower and much more consistent temps. If my truck started at 206 or even 215 and stayed there all day I would be happy. As is now, it sits around 185 to 193.
I think it is the temperature swings and spikes that hurt our aluminum engines and heads. Just IMHO.
I would have saved alot of money and time by doing the inline change first, or maybe not looking at my code reader. I've had my truck so long I'm way past "Rover knows best" and have transitioned to "forum knows best".
Wow, and to think I get nervous at anything over 205. I have a completely new cooling system from radiator, hoses, 180 thermostat, water pump, and still run Dexcool. Wednesday, outside air temp was 80, ac on auto (high) pulling a 3500 lb trailer up some long (1-2 mile grades) I never got above 205 at 55-65 mph. In town I stayed around 195-197. I am happy with my temps but would like to know how some are getting below 195 with the factory set up.
the electric fan will turn on at 212F and off at 202F
For engine cooling during normal running:
⇒ On 100 °C (212 °F)
⇒ Off 94.5 °C (202 °F)
For A/C system:
⇒ On When vehicle speed is 50 mph (80 km/h) or less and ambient
temperature is 28 °C (82 °F) or more
⇒ Off When vehicle speed increases to (62.5 mph (100 km/h) or ambient
temperature decreases to 25 °C (77 °F)
For engine cooling at ignition off (to counteract heat
soak):
⇒ On If, within 10 seconds of ignition off, intake air temperature is 60 °C (140
°F) or more and engine coolant temperature is 110 °C (230 °F) or more
⇒ Off After 10 minutes or if engine coolant temperature decreases to 100 °C
(212 °F)
For A/C system:
soak):
(212 °F)
I've yet to see my fan kick on with ign off as on a previously owned vehicle but haven't been through a summer with it yet.
"would like to know how some are getting below 195"
Having read nearly every thread on the subject here are the common items most missed...
- Using the OEM grey 180 stat. Some of the cheaper aftermarket ones do not perform as well.
- Green coolant, not Dex... Many reports of better temps.
- Flushing the block thoroughly, not just the radiator. As mentioned with vinegar and water using block drain plugs.
- Proper bleed procedure to get out every bit of air.
CANAMDiscovery
01-09-2013 12:42 AM
jfall
06-24-2012 03:45 PM
