coolin hoses question?
Old Feb 14, 2009 | 04:43 PM
ne1949mozda's Avatar
Angry coolin hoses question?
hi guys, my question I went to shop to see where is coolin leaking a small leak I can smell
antifreeze. Mechanic told me cooling hoses shound'n be so hard.disco was not runin at time we look.mechanic said I have head gasket blown or block.i believe leak comin from radiator.is possible what he said is true!
thank you for your time.
Old Feb 14, 2009 | 05:41 PM
Your english is hard to understand...you are leaking coolant, your mechainc says it is a bad head gasket, you think it is the radiator, is this right?
Old Feb 15, 2009 | 10:07 AM
Do you live in the States, if so, e-mail me your tele number and I will be glad to call and help you with this.
Old Feb 15, 2009 | 02:33 PM
I told mechanic I believe coolant is leaking from radiator and he said it's not worth it change
radiator because I have head gasket blown. he says top hose over radiator is hard that is not normal.
Old Feb 15, 2009 | 02:59 PM
yes, you can say I have bad headgasket and radiator.
Old Feb 15, 2009 | 04:23 PM
Your mechainc pressure tested the cooling system and said bad head gaskets? AND bad raiator?
How many miles are on the truck?
Old Feb 15, 2009 | 04:31 PM
okdiscoguy's Avatar
It is possible to have a bad head gasket. If your radiator had a leak, and caused it to overheat, it could pop a gasket, and possibly the motor.
A hard upper hose would not indicate a blown head gasket, though. Just means your system is holding pressure, indicating nothing is wrong.
If you can see a leak in the radiator, replace it. Then have the cooling system tested by another shop. That will give you a second opinion.
Old Feb 15, 2009 | 05:58 PM
no, he did not test it, he just said it.he did not say anything about radiator.I said it,
I believe is radiator.when you look it I can see where is kind of wet and where is dry.
64000 miles
Old Feb 15, 2009 | 07:01 PM
You need to have the cooling system pressure tested to pinpoint the leak.
Yes a overpressurized radiator hose can be a sign of a blown headgasket, but the cooling system really needs to be pressure tested to know for 100%.
Old Feb 15, 2009 | 08:15 PM
llPANCHOll's Avatar
Probably is a head gasket, putting this with his other thread, hes probably is getting combustion gasses in his cooling system as well as pressurizing his crankcase causing the huge leak he reported in the other post.
**Opinion rendered by a carpenter and should be taken with a grain of sawdust
AZRover
Jun 1, 2015 05:47 AM
djessopeng
Oct 12, 2007 10:27 AM
98TDIAUS
Nov 26, 2006 11:13 AM
hzuni
Jan 24, 2006 11:34 PM
hzuni
Jan 10, 2006 12:31 PM
