Cooling assistance
Old Oct 3, 2017 | 04:40 PM
JEFIII's Avatar
I used a Hayden 2991 Premium Fan Clutch from Amazon. The Dorman 620-112 Fan also from Amazon bolts right on. Nice set up! JEFIII
Old Oct 3, 2017 | 04:53 PM
Best4x4's Avatar
I'm running 3 from Auto Zone on all my D2's.
Old Oct 3, 2017 | 07:33 PM
dtmbinb's Avatar
I run the Hayden and Dorman setup as well. Great set!
Old Oct 3, 2017 | 10:40 PM
Richard Gallant's Avatar
Thanks to everyone for your feedback and suggestions, I took the time to flush the rad this afternoon holding off on the block and heater.
After a short 4 letter word struggle with factory hose clamps, I found a 1.5 to 2 inch piece of ribbed wire loom in my catch basin with the anti-freeze.
Given the washed gray colour of it I am pretty sure it came out the lower rad hose area.
Nothing else of note came out other than a few bit small bits and some "sand", all of that material might have covered a nickel.
Produced to flush forward 3 times followed by reverse 3 times.
Closed it all up, installed my new gray soft close thermostat. Re-filled, bled and let her idle. The expansion tank dropped about a 1/2 inch, in 15 minutes of idling temp never broke 199.
Went for a 30 minute drive this, is the good news temps ran between 188.6 and 194 max even with some short idling 2 -3 minutes. That is a drop of between 10 and 14 degrees F. Tried a steep hill in the neighborhood temp stayed solid at 190.
As a bonus the annoying tick that showed up intermittently at idle seems to have left. Leading me to believe the dealership, I bought from put too light an oil in, I need to check with him.
I suspect that chunk of wiring loom was a a large part of the problem, I still have to replace my fan as 1 blade is broken.
Old Oct 4, 2017 | 10:46 AM
dtmbinb's Avatar
Great news!
Old Oct 4, 2017 | 01:21 PM
JUKE179r's Avatar
I too went with the soft thermostat, and the Hayden and Dorman. Plus I bought an OEMTOOLS Cooling System Pneumatic Refiller Kit #24444 to totally bleed the air from my coolant system and refill.
I've had engine coolant temps as high as 228 degrees but now they are down to 186 - 192 degrees and no more waterfall noise.
https://www.carid.com/oem/cooling-sy...mpn-24444.html
KCRich
May 18, 2010 07:08 PM
bobbydigital
Oct 23, 2008 11:16 AM
starcraft
Oct 9, 2008 07:17 PM
LRXD
Sep 28, 2006 06:21 PM
bgamble7
Apr 21, 2005 04:58 PM
