Cooling liquid leaking problem
Old Jul 3, 2009 | 03:40 AM
Helmuth van Es's Avatar
Default Cooling liquid leaking problem
Couple of weeks ago I posted an overheating problem with my Series II TD5 Discovery. Turns out there was a leaking problem after all due to tired clamps around the hoses connected to engine, radiator etc. Well that is what I thought 2 repairs done now with a total of 3 clamps being replaced. One leak I had seen myself and was clearly coming from around one of the replaced clamps. This morning after the second set of clamps was replaced: again coolant leakage. It seems only to occur when the engine is cold not when driving. What to do? Could it be more clamps leaking or something major. It has almost 201k kms on the clock so I am thinking maybe time to trade it in or sell it. But I love it too much . Any suggestions much appreciated.
thanks
Old Jul 3, 2009 | 05:00 AM
antichrist's Avatar
Have you pulled the hoses and inspected them internally for deterioration? Also inspect the fittings on the engine, they can get corroded and make it hard to get a good seal.
You may likely have something else going on, but get the leaks tended to.
Old Jul 3, 2009 | 09:39 AM
Just have someone do a coolant pressure test when the engine is cold.
Old Jul 3, 2009 | 11:49 AM
Default leak
thing is they did the pressure test several times...
Old Jul 3, 2009 | 11:50 AM
Thanks. With sealants you mean rings around the fitting or sealant tape ?
thanks
thanks
Old Jul 3, 2009 | 12:52 PM
f you are taking your truck back to someone that has supposedly done a number of coolant test and not fixed the problem, why do you trust them?
Old Jul 3, 2009 | 02:37 PM
I would replace all of your coolant hoses, hoses go bad over time and can fail.
Old Jul 4, 2009 | 02:10 AM
Default coolant leaking
I was just about to wonder about that . Thing I have seen them doing the pressure test. They are pretty competent it seems but fact remains, not fixed...
Old Jul 4, 2009 | 09:33 AM
Well with 125,000 miles on the truck if you have never had the coolant hoses replaced that is where you really need to start, if the shop did not recommend this then I would find another shop.
When rubber gets old it will swell, shrink, get brittle, really soft, all kinds of stuff.
Replace the hoses, all the radiator hoses as well as the heater hoses.
Old Jul 4, 2009 | 12:32 PM
lipadj46's Avatar
This is a pretty easy fix that you can do just as well as any shop, new tube, new clamp, done. You are lucky you do not have a gasket leak, a hose leak that you can see is a simple almost welcome fix (when compared to other leakage problems).
