Cooling system help!!! Leak
Merry Christmas all,
Heading out to do some wheeling with the family and cooling fluid is all over the ground. The bleed screw in the t section of the cooling pipes has cracked an coolant sprayed everywhere. No over heating, but is there a better part than the stock as I'd like to replace and not deal with it again.
Thanks in advance
Thanks in advance
Thanks again
I went with the AB kit fOr lack of fab skills i figure I might as well throw them the business and save myself the hassle of the stealership
You can use this brass one instead, it is more durable and will probably last the life of the truck. http://www.bmpdesign.com/product-exec/product_id/6857
