cooling system presure
Old Mar 18, 2011 | 10:51 AM
franz's Avatar
Default cooling system presure
2002 disco II 62k mi
Having trouble with cooling system presure. I 've been adding coolant for last 6 months. Sometimes a hose blows off. Never overheated untill recently. Changed thermostat, appeared to correct problem at first but now it overheats after I drive about 4 or 5 miles after cold start. I pull over and it cools off and is good for the rest of the day. Sounds like thermostat is sticking so I changed it again but problem still persist.
Old Mar 21, 2011 | 02:07 PM
franz's Avatar
I started bleeding system in the evening instead of in the morning. Hasn't overheated last two times I drove it.
Old Mar 21, 2011 | 08:11 PM
unimoged's Avatar
Check your pressure cap. Sometimes, when an anti-leaking compound is added to the cooling system, the particles accumulate on the pressure relief valve in the cap causing system pressure to go higher than 16 LBS, blowing a hose.
In regards to bleeding the system, the overflow tank needs to be higher than the bleed screw to be able to get all the air out. So, either use a long funnel or lift the DII from the right side with a floor jack or park it on a steep incline sideways.
Old Mar 22, 2011 | 08:52 AM
franz's Avatar
Thanks for the tip. I will order a new cap. I'm not aware of any anti-leaking compond being added to the truck. May have been done before I purchased it. I had been mixing different brands of coolant before I was made aware thats not a good idea.
I'm really not sure if I am bleeding the system correctly. I was not aware that the overflow tank needed to be higher. Are there any aother procedures for proper bleeding that I should know?
Old Mar 22, 2011 | 10:34 AM
You need to go a step or two past what you have done so far. There is a real good chance you have a blown head gasket and the longer you let this go the better the odds are that you will also crack a head or drop a sleeve, then there goes the engine.
Old Mar 22, 2011 | 11:46 AM
franz's Avatar
A mechanic told me I have a leaky head gasket. He said on a scale of 1-10 he would rate it a 3. He said if I keep coolant level up it should be OK for a long time. Another mechanic said the motor should be completly rebuilt, including sleves and rings. Said cost would be upward of 5 thousand. Another said he really didn't know what was wrong. My mechanical knowlede is limited but I love my rover and want to learn more about it. It's not my primary vehicle but I want to be confident I can make short trips and get off road when I get a chance. Any suggestions are greatly appreciated.
Old Mar 22, 2011 | 11:56 AM
Bundu's Avatar
Banned
Fix your leaky head gaskets before it becomes a bigger problem - because it sure will.
Old Mar 22, 2011 | 03:33 PM
franz's Avatar
Sounds like good advice. What is a reasonable ball park price for head gasket replacement?
Old Mar 22, 2011 | 03:43 PM
Bundu's Avatar
Banned
Around $2K give or take a couple hundred. Tom Rowe (antichrist) is in GA, he may be able to point you to a good shop.
Old Mar 22, 2011 | 04:11 PM
franz's Avatar
Thanks, I'll check in to it. I'm willing to spend the money. I just want to be sure I get it done right if I lay out that much cash.
