Correct STI Plugs?
Correct STI Wires?
For anyone that's installed STI wires did you have the same type of coil connectors on yours as the ones attached?
I had one that "clicked" into place and the rest, no matter how hard I pushed, wanted to "click"...once in place I was able to take them back out with minimal pressure...to the point that I'm worried they'll pop out while driving over rough/bumpy surfaces...
Did the place I ordered them from send me the wrong wires? I also noticed that the numbering of the wires was off, eg. the STI wire numbered 8 did not correspond to the length of #8 of the OEM wire, etc...
Alright, received the right wires this time...the supplier I ordered them from thought I was crazy, and swore up and down that they should have been the right wires to begin with...nevertheless when I opened the new box they were different...different as in the right ones for my year disco...after a little bit of research it looks like they sent me a set for a 97 disco the 1st time...
Much easier install this time around with the right wires...install time was about 2.5 hours...about half the time it took me the 1st time around as I wrestled with the wrong wires trying to make them fit...
...a word of advice...double check that you receive the right wires...the box in which I received stated that they were for my year d2 on the outside...even the invoice stated that they should have been the right ones.
This is very interesting. I just ordered a set of the 8mm Kingsborne wires just before the hollidays, and they came with the wrong coil ends on them as well? could STI and Kingsborne be the same? Anyway, I called and they already were aware of the issue and shipped me out the correct set quickly. Nice looking wires, and since I am doing a head gasket job, it isn't a big deal to wait the extra couple days...
marsyas
02-25-2021 08:11 AM
cosmiccharlie
05-13-2015 10:45 AM
