could anyone please give me some relay help????
Old Jan 21, 2015 | 09:15 PM
dobe1canobe's Avatar
Default could anyone please give me some relay help????
2000 disco 2 .... what are the part numbers/relay numbers for 6-10? i was told they were all the same so i switched them around trying to see if i had a bad relay. but i started looking closely and they are not the same. does anyone know of a diagram or the relay numbers for the 5 diffrent slots on the top black ones its r6-r10? thank you
Old Jan 21, 2015 | 09:28 PM
bmeier's Avatar
does this help?
Attached Thumbnails could anyone please give me some relay help????-relays.jpg
Old Jan 21, 2015 | 10:06 PM
OverRover's Avatar
I'm seeing YWB101300 for r6-10. Are you seeing relays with more blades/amps?
Relay - ABS Pump/Auxilary Circuits (Genuine Part # YWB101300 ) - Land Rover connector\relays\flasher from Atlantic British
Might be a possibility>> http://www.roverparts.com/Parts/YWB10027L
Old Jan 22, 2015 | 09:01 PM
ya it helps a little but i was looking for the relay numbers so i can verify there the right relays in there cause there are 2 diffrent ones out of the five. thank you though.
Old Jan 22, 2015 | 09:07 PM
@ overrover ya i have 2 diffrent relays but i was hearing that there all suppose to be the same for r6-r10 and i have had abs and sai problems since i bought the truck. so i was gonna replace all the relays but i cant find what there suppose to be lol
Old Jan 22, 2015 | 09:09 PM
yes thanks im gonna order one and see if the numbers match any of mine
Old Jan 23, 2015 | 06:42 AM
bmeier's Avatar
Have you bench tested the relays or did you just try them in different spots?
Scroll down to relays, they have the part numbers next to em,
Discovery II Electrical Switches and Relay - Rovers North - Classic Land Rover Parts
Old Jan 23, 2015 | 08:56 PM
awsome thank you bmeier!
Old Jan 23, 2015 | 08:57 PM
thank you overover im looking that up now
Old Jan 24, 2015 | 12:08 AM
bmeier's Avatar
no prob
