A Couple of Things...
Dash Clock - The bulb is burned out. Do I need to purchase the Land Rover specific replacement bulb or is it possible to get a replacement from a local auto parts store and make it work?
Sunroof(s) - Both the front and rear sunroof "stick" when opened. They tilt up with no issue, but they will stick once tilted up. The rear one will slide back after a few seconds and the front one is hit/miss. Sometimes the front one will go ahead and slide back after a big "clunk". Is there anything I can look at/adjust to get it to stop sticking?
Rear Window Washer - I can hear the pump activate, but no fluid comes out. I've traced the lines as much as I'm able to and I'm not seeing a leak anywhere. Any ideas on where I should look? The workshop manual isn't very helpful on this one.
Any bits of advice on those three issues would be greatly appreciated.
bulb - https://landroverforums.com/forum/ge...023/#post23692 or NAPA
There is a whole section on sunroofs in the RAVE shop manual. Silicone spray? I don't have them and am damn proud of it!
Could be stuck check vave on rear hose.
Odd, when I did a search for clock, that thread didn't come up. You mentioned NAPA, is there a specific part number of bulb that will work?
I did look at the D2 Workshop Manual in the sunroof section, but it was mostly instructions on how to completely remove the thing and I was hoping for a quicker fix than an all day teardown/replacement.
I thought it might be the flow control valve. That'll have to wait until I can tear the bumper and grill off to get to the pumps.
