CPS: Anticipatory Replacement Or Wait for Failure?
Old Dec 5, 2019 | 11:23 AM
boston4's Avatar
Default CPS: Anticipatory Replacement Or Wait for Failure?
I have an 01 D2 with ~170k on the clock. I just purchased the truck recently and have been catching up on the major service items and was wondering whether I should go ahead and replace the crankshaft position sensor. From what I can gather, it's not a repair that you can realistically make roadside, due to the high temps among other factors.
I don't know how long the part typically lasts but it seems like it's an inevitable point of failure - presumably it's been replaced at some point, but I can't be sure. It's only like $40 for the part, so it seems like cheap insurance.
I did some searching but couldn't find much on the general consensus here - do you guys recommend replacing it proactively or taking a "if it's not broke don't fix it" approach? How long do the parts typically last?
Old Dec 5, 2019 | 11:36 AM
redwhitekat's Avatar
I wouldn’t usually if it fails while driving you would wait until it cools down and some have poured water to cool it down
if anything have a spare on hand and the right tools small ratchet etc
Old Dec 5, 2019 | 11:37 AM
Externet's Avatar
Not because of the unknown sensor duration, but for the action of getting hands and tools in there with the risk of dislodging/damaging some wire/connector that can be for something else; I would not touch something that works fine. Prefer the approach "if it works, do not touch it"
Old Dec 5, 2019 | 12:05 PM
Sixpack577's Avatar
There are no other wires around it, and there's nothing else that be damaged there.
It's just in a tight spot, but not a big deal to replace.
Old Dec 5, 2019 | 12:24 PM
Dave03S's Avatar
In 200,000 miles of ownership I have yet to have the CPS fail. Knock on wood. It's not a doom and gloom thing like your cooling system which you are good to proactively maintain.
Old Dec 5, 2019 | 12:28 PM
SundayFunday's Avatar
I have changed mine on the side of a road situation. Had a replacement with me. And with enough time to let things cool- it’s not impossible.
Old Dec 5, 2019 | 02:46 PM
acg's Avatar
acg
Mine failed at 110K miles. I carry a spare one because I off-road frequently in some remote areas.
Old Dec 5, 2019 | 03:12 PM
Richard Gallant's Avatar
No harm in proactively replacing, keep the old one as a spare. Getting the CPS undone is 10 minutes. The damm wiring connector is a bastard though 10 to 20 depending on your luck to disconnect and reconnect.
Old Dec 5, 2019 | 03:36 PM
acg's Avatar
acg
To the OP, Lucky8 has a YouTube video which I used. Great set on instructions.
Old Dec 5, 2019 | 07:56 PM
Extinct's Avatar
Failure cause is heat soak from the exhaust manifolds, LR put a cover over it and painted the cover silver to help. It does help a bit but not as much as is needed. I wrap my covers in aluminum foil and/or put an aluminum heat shield between the cps and exhaust manifold, helps tremendously. I had one going out, would not start hot. Put the heat shield on it and now she works fine for the last 30k.
