Crack in the block?
and just how do you plan on making the transmission shift? the kit you see is for a D1 much less sophisticated vehicle. good luck and be sure to check back in.
Because all the other people the were just going to throw a small block Chevy never did complete it.
Don't know about other peoples success or failures but I will make this work. If I run into a specific problem such as computer issues, I can deal with that too.
Already purchased the engine and went with the 4.3 v8 from a 75 Chevy Caprice. Even though this low mile engine didn't come with accessories, I'm going with the Chevy AC Compressor and alternator which are both on the right side of the engine. I will use the Rover's Pumps and leave them on the left side with a modified mount.
The Rovers radiator should be fine with electric fan(s) for cooling.
I will start a thread on it shortly and document it as I go for the benefit of others.
Any progress on the Impala swap?
I guess I will give the 5.3 LM7 truck motor a chance to live in a Rover chassis. The key to this whole swap may be the ability to successfully "trick" the Rover computer into thinking the engine is running so it will shift the transmission. SLABS will most likely still have issues also.
99Discovery
Dec 16, 2013 07:18 PM
Blakesrover
Feb 21, 2013 01:43 AM
JBEGIN
Jun 27, 2009 12:38 PM
