Cracked Block?
#121
i had a sudden loss of coolant, temps started to run higher and I could smell coolant.
i had a shop do the front cover. i wasn't confident i could tackle that type of work. now after having done the water pump the extra steps to do the front cover don't seem that intimidating.
I should have asked this earlier today but didn't think of it.. duh. How did you determine it was the front cover? Was that determined by a pressure test or something? Apparently they've run all the tests and are having difficulty determining what the issue is. I'm so frustrated I'm ready to park it and not even think about it at all. And that's sad.
Christina
#122
KernowDiscovery (08-08-2018)
#123
I don't see this being head gaskets but what do I know. No white exhaust, no steam cleaned spark plugs, combustion test failed (faintly) after 20 minutes of running and big dumps of coolant.
No noise which I'm reading about a lot with slipped liners.
No overheating so how would the block crack?
Viscous clutch is running 24/7.. weird.
No misfires
yada yada yada.
This is sooo frustrating...
I'll stop venting.. thanks for listening. Just at my wit's end.
#124
Have you considered just buying another D2?
I see lots of overpriced junk, but occasionally, a good truck at a good price pops up.
Again, given the cost of a new engine, plus labor, you may be better off.
Extinct has a great looking black(03?) for sale, with everything it needs done, and then some.
You could buy something like that and still save money...plus you'de have a parts truck.
my advise save up and buy a new block
here in Canada a new or remanufactured long block runs 10 k
now in on any other vehicle this would be crazy however these discos are comfortable they are different looking and very capable and starting to become very rare in good shape
I'm thinking of selling mine and I'm getting offers of 8-9 k I had to back out of selling because I'm seing such a demand now for this and I really don't want to sell it however I may increase the asking price to 12 k cdn and wait
and the only reason why I'm considering selling is because of these engines.
The thought of spending 10 k kinda turns me off
#125
however you stil got the same ****ty engine
I agree the engines are junk.
That's why I suggested an LS swap in previous posts.
KernowDiscovery (08-09-2018)
#126
Hi Jastutte,
Christina
Christina
#127
#129
#130
So I stopped in at the shop on my way to work and asked if they had conducted a pressure test. When we spoke on the phone the first time to set this up they said that they would so I was surprised today when he said 'what kind of pressure test?' He didn't remember me either so that was interesting.. I said 'I spoke to you on the phone yesterday about my Rover' and he said 'I speak to a lot of people on the phone about their Rovers'.
ARGH... I have met him before too.
So anyway, I said 'you have my blue Land Rover out in the parking lot, we spoke yesterday about the strange symptoms and I'd like to discuss it'.
and this is what I said:
'from what I've been reading, there are 2 main areas where Rover owners are seeing coolant entering the oil. Headgaskets and the front cover. If you were to drop the oil pan and do a pressure test, if the front cover was the culprit, you'd see leaking into the pan.'
His ears perked up..
He seemed surprised.
The man sitting in the lobby waiting for his vehicle seemed amused.
'I like this idea', he said. 'It's out of the box'.
Thank you LRO and LRF for the tips and experience.
I went on... 'if you don't see coolant leaking out during the pressure test, let's rule out the front cover. Then maybe we could look into digging into the cylinders and go from there.'
He brought up an image of the gasket on his computer and agreed that 'yes, it could leak there'.
We did discuss the combustion test again and how they didn't see anything until after 20 minutes of running when the chemical test turned green. SO... my thoughts are:
1) I may have a small head gasket leak as combustion gases showed eventually
2) I may have both.. a small head gasket leak (as I've dealt with these before) and a major leak somewhere else (front cover, intake manifold gasket, etc.)
3) I could be screwed and it's a slipped liner or cracked block.
His Rover tech is off work for a few days so no one will be looking at it until next week at the earliest. At least I have a process of elimination direction and they are on the same page now. We shall see.
Thanks again,
Christina
Thanks again,
Christina
