crank pulley wobble.
Old Apr 8, 2012 | 03:13 PM
94svt50's Avatar
Default crank pulley wobble.
Alright humor me with another question. I noticed the crankshaft pulley has a wobble. The center part where the bolt is spins true its the outer part where the belt rides that wobbles, I assume the rubber part between the two pieces is to blame. Its enough of a wobble at idle that the belt walks side to side on the closest idler pulley. This wobble seems most prominent at idle and is not noticeable at higher revs. The replacement pulley from AB is $670! So this is not an option. Maybe they all wobble? Is this a big problem?
Old Apr 8, 2012 | 03:37 PM
Buy a used one, it should not wobble.
Also check with Trevor at RovahFarm - Parts for Land Rover Cars and Accessories - Land Rover Discovery, Range Rover, LR3, LR2, Land Rover Defender, Freelander and Land Rover Series, and of course e-bay and Google.
Old Apr 8, 2012 | 03:51 PM
94svt50's Avatar
Thanks, I guess used is the way to go, just hope I dont end up with one worse then mine.
Old Apr 8, 2012 | 04:40 PM
If you research it I bet you will find others from other cars that fit and are much much cheaper.
Old Apr 9, 2012 | 07:27 AM
Higgs Boson's Avatar
Contact Paul Grant, I know he just parted a truck with a bad block. I saw it last Tuesday when I was there getting parts. He won't sell you junk.
Old Apr 9, 2012 | 04:36 PM
94svt50's Avatar
Thanks for the tip. I just ordered one from Pt Schram, great guy to deal with!
SolbergFanBoi
Sep 21, 2012 11:45 PM
benreal
Apr 27, 2012 08:47 PM
greg409
Feb 24, 2010 12:35 AM
lipadj46
Nov 15, 2009 11:27 AM
shonuff93
Oct 7, 2009 07:24 AM
