Socket size for crank shaft pulley?
Old Nov 14, 2009 | 06:38 PM
lipadj46's Avatar
Default Socket size for crank shaft pulley?
What is the size of the nut on the crank shaft pulley (the one you turn to turn the engine)? I thought it was 25mm but that is too big. Is it 24mm or is it SAE? My socket set is lacking in the larger sizes.
Old Nov 14, 2009 | 11:50 PM
SpdDemon426's Avatar
1 inch socket with a breaker bar. Should come right off..
Old Nov 15, 2009 | 11:27 AM
lipadj46's Avatar
I tried a 1" and 25mm both would probably work but is too sloppy a fit for my liking (would hat to round it off at this point). I am going to return the 25mm and get a 24mm socket.
Antmen
May 10, 2010 10:04 AM
sgnhis
Apr 9, 2010 07:48 AM
sgnhis
Apr 8, 2010 08:20 PM
lipadj46
Aug 17, 2009 10:08 AM
atikovi
Apr 5, 2007 10:45 PM
