Crank sensor
Old Jun 30, 2009 | 02:11 PM
thehulk's Avatar
Default Crank sensor
Hi all, after reading all the info here I matched up the symptoms on my auto 03 disco with a bad crank sensor. Ordered from autozone for 65 bucks. Then when I picked it up they told me it has to match the 7th numberr to the right on my VIN number. With my luck, it does not match. They said they have two sensors for two different VIN ranges. The seventh number to the right either has to be a 6 or a 4. I called the local LR dealership to see if they have two different sensors for two different VIN ranges and they told me they only have one.
Will the crank sensor I got from autozone work on my truck even if they say that part is not for that VIN range or should I pay more than half the price at the dealership?
Thnx
Old Jun 30, 2009 | 02:34 PM
I believe they are wrong. For as many years as I have seen these fail and watched others replace theirs, there is only one made for the 4.0.
Go to Rover Connection and check what they show.
Old Jun 30, 2009 | 02:48 PM
thehulk's Avatar
Just checked and I need the ERR7354. Which looks exactly like the one I got from autozone, except in its a duralast box that says "CRANKSHAFT SENSOR SU5570". Theres only one crank sensor right? and mines the 4.6... Its an 03 disco with the fatal engine with 88,000 miles. Another thing, I cant take off the fron drivers side tire. Ive taken off all lugs and it seems to be stuck together. Ive even resulted to hitting it with a big piece of wood several times but it still seems to be stuck. Is there a certain trick to getting it off?
Old Jun 30, 2009 | 03:21 PM
http://roverparts.com/Parts/ERR7354G.cfm
Install it, there is only one crank sensor for a DII and it covers all years.
Old Jun 30, 2009 | 03:22 PM
As for getting the wheel off, with the lug nots off the wheel turn the steering wheel from side to side and see if it breaks loose, do this with the wheel on the ground.
Old Jun 30, 2009 | 04:13 PM
thehulk's Avatar
any tips on taking out the sensor? The best approach seems to tbe thru the wheel well and my tire seems to be STUCK on there. Any other ideas?
Old Jun 30, 2009 | 04:17 PM
Pay someone else to do it.
Old Mar 17, 2010 | 02:35 PM
Thomas_DicoII's Avatar
Default Crankshaft Sensor Location 01 Disco II
I believe i am having an issue in my 2001 Discovery 2 with my crankshaft sensor. i have the replacement part however i am having trouble finding the location of it on the engine! A little help PLEASE!
Thomas
Old Mar 17, 2010 | 03:11 PM
okdiscoguy's Avatar
Right on the front of the engine. 3:00 on the crank.
What makes you think yours is bad?
Old Mar 17, 2010 | 04:51 PM
It will run for about 20 mins, then idle down, then shut off. Once i try to restart it will crank but not start up. After it sits for about 30+ mins it will fire right back up...no problem...20 mins later...same thing. iv troubleshooted the battery, alternator, and fuel relay, all check out good. After doing research i found a couple of posts pointing the Crankshaft sensor. So i figured i would give it a shot.
Iv looked for the last 2 hours and cant seem to find it so i am now looking to see if there is a diagram online to give me a visual reference.
Thanks for the info!
Thomas
