crankshaft position sensor
Could someone send me a pic or detialed explanation of where the crankshaft position sensor is located on an O2 Discovery II? I cant find this thing. Also, i know there is a thread on here of directions on switching it out but i cant find it. Any help is appreciated. I am also guessing the part i need is Bosch.
It is in the Rave CD or you might want to try and do a search on the LRO, in the Disco section, there is a video on how to replace it.
Have you already bought yours, so you know what it looks like, it is located on the drivers side of the block, back side close to the bell housing.
Why are you replacing yours?
I'm one of the people pushing the crank pos sensor, you need to read the rave.
I can't speak for the DII, but for the DI, (possibly the same), it will light the check engine.
Also the symptoms are the truck will not restart when hot. (it's not just a matter of more cranking)
If you leave it sit for say 15-20 mins, it may start just fine, like nothing's wrong.
Both of mine started great when not hot. (maybe your's has been acting up longer tho')
luck,greg
luck,greg
Well Mike it started off with a rough start when the engine was hot which led me to believe the CPS. However, today i went out to start it (cold) and it took about 3 cranks for it to start. I let the vehicle warm up and settle to idle, turned it off, started it again and it started right up. I turned it off and it started right up again, so now i'm not sure what it could be. Any ideas?
