Crazy Demon Land Rover 99 discovery II
Old Apr 9, 2009 | 07:30 AM
Blake518's Avatar
Angry Crazy Demon Land Rover 99 discovery II
Ok, I have the 3 amigos ABS problem that I have not had money to fix. Now I have the alarm that wants to go off for no reason at random hours, any suggestions? Now last night my horn decided to come on at 2:30 in the morning and a t 6:30 this morning just came on full blast for no reason. I punched the steering column and it stopped. Has anyone ever heard of this happening and what might be the cause, so I am try to fix?
Any words of wisdom will be greatly appreciated.
Thanks
Old Apr 9, 2009 | 12:42 PM
okdiscoguy's Avatar
Ignition switch going bad? make sure your key is all the way back before removing it.
Old Apr 9, 2009 | 01:40 PM
salve7's Avatar
punch it again harder.
Old Apr 9, 2009 | 05:35 PM
When you finally figure out that hiting it won't work, then shout and lets see if we can get you thru this.
Do you set the alarm at night, do you super lock it, do you leave any windows cracked open?
Old Apr 9, 2009 | 06:12 PM
AK Rover's Avatar
It's possessed. Better call an exorcist.
Old Apr 9, 2009 | 06:54 PM
Is just the horn honking or are the lights flashing too?
I have heard of this before and your answer if very important.
Old Apr 9, 2009 | 09:28 PM
NiteTrain's Avatar
a little bit off topic here, but what is "super lock"?
Old Apr 9, 2009 | 09:36 PM
"super lock" is a dead bolt in the door that does just what a dead bolt does, it goes into the door frame and makes it almost impossible to get the door open.
The only problem with it is that if your battery goes dead while it is super locked you will need to have it towed to the dealer if you ever want to get in your truck again.
You will need to open the hood from the outside and charge the battery and then once you get the truck open you will need to reset the alarm.
Dont use the super lock.
Here is a little tip from your uncle Spike, never keep anything inside a car that is of value, cars are WAY to easy to break into.
A spark plug thrown from 3 ft will shatter the side window.
Break the window, reach in and grab the camera and gone in under 30 seconds.
Super locked or not your camera is gone.
Old Apr 9, 2009 | 09:46 PM
NiteTrain's Avatar
how do you engage super lock? or better yet..how do you AVOID engaging super lock?
Old Apr 10, 2009 | 08:18 AM
Super lock was a feature offered on the D2's so that if you double locked your truck, the door locks would dead bolt lock, making it impossible to open.
