Crazy new temps. Need help
Old Dec 23, 2018 | 07:50 PM
mln01's Avatar
The thermostat has NOTHING to do with how high the temp gets, unless it gets stuck closed.
Old Dec 23, 2018 | 08:08 PM
Best4x4's Avatar
Yep 180/195F just determines what temp the thermostat opens. Temp depends on air flow, condition of the entire cooling system, load on the vehicle, terrain, and weather conditions. It’ll help keep it from building up a high engine temp but it’ll climb.
Old Dec 23, 2018 | 11:01 PM
shanechevelle's Avatar
THANK YOU!
Everyone here just keeps throwing out their tstats. Drives me up a wall.
Old Dec 23, 2018 | 11:06 PM
Dave03S's Avatar
Wow, I guess I like me a stuck thermostat then because when I changed to a 180 the top temp I got lowered from 215 to 199. I bled it the same but I guess I must be mechanically challenged in some way. i've apparently done the same stupid thing over and over again with the same results. I must be some crazy exception to the rule.
Old Dec 24, 2018 | 01:48 AM
The Deputy's Avatar
Exactly. I've all but given up on reading coolant temp topics here.
If you have a 180 thermostat...it should run a few degrees within that range (3 or 4 degrees), not 19 degrees higher. If you have a 195...it should run within a few degrees of that, not several degrees hotter. If it is running higher...most likely you have another issue with your cooling system. Bad clutch fan, partially plugged radiator (internally, coolant flow or externally, air flow), weak belt tensioner, worn belt, defective thermostat, restriction in cooling system, bad water pump and in some rare cases..a bad trans (and the trans cooler is super heating the cooling system with its higher than normal temps).
Brian.
Old Dec 24, 2018 | 11:22 AM
Ben Matheson's Avatar
Definitely some type of flow issue. I used to have a good visible flow back into the reservoir but now it's substantially less can only see movement if I rev it fairly high. I'm stumped
Old Dec 24, 2018 | 09:51 PM
mln01's Avatar
Apparently
Old Dec 25, 2018 | 07:05 PM
Update
started the Disco today and lifted the hood. Visible flow into the coolant bottle had returned to normal. Temperature behavior also back to normal and never got over 197 when coming to a stop. ImI thinking some type of crud came out of the heater core and was lodged some place. I'll give it a flush.
Old Dec 27, 2018 | 11:20 AM
What's funny is, a stat can open in a pan of water at 180 but somehow once installed it becomes faulty.
Old Dec 27, 2018 | 01:57 PM
Best4x4's Avatar
Exactly!
GCBurke
Mar 21, 2019 04:54 AM
escott16
Dec 28, 2018 05:36 PM
Chemcorp158
May 21, 2018 11:22 AM
thatbaldguy
Nov 26, 2016 10:27 PM
Proto31
Nov 25, 2013 05:09 PM
