Crosslinking Air Suspension?
Old Oct 14, 2007 | 03:12 PM
ajh's Avatar
ajh
Default Crosslinking Air Suspension?
Anyone tried crosslinking the rear suspension? Then when you're offroading you could install a solenoid valve that would activate in low-range that would allow air between the sides to flow freely. I'm told if you do this you need to keep the swaybars though to keep things upright. I'm curious about the pros and cons of swaybar removal vs crosslinking. Anyone tried?
Old Oct 15, 2007 | 07:59 AM
Default RE: Crosslinking Air Suspension?
Do you no longer like your truck? Seem to be going through a lot of issues and potential changes on it. As for your question, I wouldn't even try what you are suggesting. The SLS is processing angles and loads in millaseconds keeping your truck level.
With all the wheeling I have done with my 99 which has the SLS and ACE, I wouldn't change a thing to try and improve it other then to find some longer shocks.
Old Oct 15, 2007 | 08:54 AM
ajh's Avatar
ajh
Thinking about things doesn't mean they're a good idea or that they're likely. Sometimes it's just an exercise to see if an idea has any merit at all. It's not always 'support' sometimes it's just fun discussion... I hope.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
